Показано с 1 по 10 из 17
    Вопрос Silabs/lart будет ли работать в CF2 на Windows7 ?
    Хочу перейти в машине на семерку, но закралось сомнение,услышу ли я звук радио в колонках??
    Nissan Almera N16 продана
    Продвинутый Аватар для didos
    По умолчанию Re: Silabs/lart будет ли работать в CF2 на Windows7 ?
    работать будет, только нужно будет один раз включить его в устройствах записи, показать отключенные устройства, включить тюнер
    Это сделал, в винде радио пашет, а вот в ЦФ не хочет
    Наверное нужна более новая ddl`ка?
    может кто поделится у кого работает радио в цф2 на семерке?
    To install:
    1. When you first plug-in your USB FM Radio in Windows 7, the audio device is disabled by default. You have to navigate to Control Panel>Hardware And Sound and under the Sound heading, click on Manage audio devices. Once the Sound dialog is displayed, click on the Recording tab. When the USB Radio is plugged in, you should see the device here. If you don't, it is probably hidden; right click and make sure Show Disabled Devices is ticked.
    IMPORTANT NOTE: Like I noted above, for some reason, when you first plug in the USB Radio, it is automatically disabled. You need to double-click it to display its properties and select Use this device (enable) in the drop-down list box at the bottom of the dialog.
    2. Navigate to %programfiles%/Centrafuse/Centrafuse Auto/RadioModules/Silabs - delete all that's there and copy the USBRadio.dll and USBRadioNET.dll from the attached zip file into here.
    3. Start Centrafuse, go to the system settings, enable advanced settings, go to Am/Fm Radio, select this plug in.
    4. Select Silabs/ADS/PCear USB Radio in device.
    5. Select Radio Receiver (FM Radio) in record line in device.
    6. Select your playback line in device to None.
    7. Select buffer radio.
    8. Click on save button and then re-start Centrafuse.
    I am developing on Win7 x64 and my car pc is running Win7 x86 (can't see a reason to use x64 version). I have a Media PC that's still got XP installed but I don't really have any motivation to try that one.
    If you want XP support, I need to have a screenshot of the USB FM Radio device that's in the audio section. This plugin searches for the text "radio" in all audio monikers and initialises the first device it finds via DirectSound. If XP doesn't have this, then this plugin will not work.
    • Тип файла: zip Silabs.zip (95.7 Кб, Просмотров: 392)
    Последний раз редактировалось didos; 23.01.2010 в 16:34.
    Попробывал, радио нету по прежнему
    С этими ddl в настройках цф вообще отсутствует пункт Silabs`a!
    Попробывал переименовать файл "USBRadio" из атача в silradio, как было изначально в ЦФ, пункт силабса появился,радио вроде как подцепилось-каналы радио начали переключаться, но на этом все и закончилось
    Это делал,пробывал даже и колонки выбирать,все равно не помогло
    з.ы. как я понял это все файлы для ЦФ3, может для ЦФ2 под семеркой нужны свои?
    попробуй эту
    • Тип файла: rar Silabs.rar (81.4 Кб, Просмотров: 362)
    Спасибо,попробую.
    З.ы. Размер файлов и дата их создания совпадает с такими же файлами-оригиналами в самой цф2.Так и должно быть??
    Цитата Сообщение от didos Посмотреть сообщение
    попробуй эту
    Попробовал.
    Пункт силабса в настройках есть, но при попытке переключить станцию, пишит радио не найдено.
    Пробывал уже и отсюда плагин.
    с ним первый раз ЦФ запустилась,станции радио выбирались,но звука радио небыло.Второй раз ЦФ вообще не захотела запускаться-висла на инициализации звука.
    Также попробывал программку USBRadio-1.7-beta5 для силабса из под винды взятую здесь , но она не запустилась.
    Ругнулась вот так
    Судя по забугорным форумам, я не один с такой проблемой
    Интересно у кого-нибудь вообще работает silabs в ЦФ2 на семерке??
    Последний раз редактировалось Fedorych; 26.01.2010 в 13:24.
    уххххх....Решил наконец то проблему.
    С домашнего компа скопировал файл mscomctl.ocx в system32 и немного поигрался с переименованием выложенных здесь и родными плагинами ЦФ.
    Выкладываю 100% рабочие плагины и злополучный отсутствующий у меня файл.
    Fedorych, а у меня ничего не помогло! и с твоими файлами тоже тишина просто...
    Что и думать, не знаю...
